跳转到主内容
加入维修社区 - 创建账户
发布于2017年7月28日,新 Nintendo 2DS XL 是 Nintendo 2DS 掌上游戏机的迭代机型。
My 2ds xl turn on, but then turns off with a small pop
So a while ago my 2ds xl’s screen snapped (upper) and it did what i am still experiencing today. I know for a fact that my upper screen flex cable was torn so i removed it, as well as the WiFi antenna. I tried isolating every cable and flex cable, but to no avail. I finally trying turning on the system with out anything connected, just the motherboard, and it still does the same thing (but of course with out the pop). Is there a way to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
According to this, the popping is a symptom of a failed system check on boot:
https://repair.wiki/w/New_Nintendo_2DS_X...
It states there are 4 components that must be validated: Upper LCD, lower LCD, inner camera, and battery. If any are damaged (or their ribbon cables, or ribbon cable connectors) it produces that popping sound.
Note that the ribbon cable connectors for the lower LCD power and RF antenna are NOT ZIF connectors like the rest. Lifting the "latch" on these breaks them such that they do no longer make a good connection. This is a common issue.
"Five ribbons must be connected to the motherboard to get it to boot to the home menu. If any of these are not connected or are damaged in a way that the system detects as incorrect the blue light will turn off and the console will not boot. These five are the Lower LCD, Lower LCD backlight, Upper LCD, Inner Camera, and the Battery (see Fig. 3). Only these five need to be connected for the system to start."
完成的
a mi tambien me pasalo mismo, sinceramente no se que hacer. Llevo 3 meses buscando mucha info sobre esto. Lo que le pasa a mi nintendo 2 ds xl, y tiene la pantalla superior muy dañada creo que cuando era mas pequeño la pise y posiblemente se rompiera taambien el cable flex. No tengo mucho conociemiento en esto pero la voy a intentar abrir. A veces enciende y otras no y hace el clasico pop, tambien fui a un sitio profesional y nada ellos dician que no lo arreglaban, me las voy a tener que ingeniar yo solo. Volvere con mas info.
完成的
添加一条评论
2个答案
I'm pretty sure the 2ds xl will refuse to boot if the top screen ribbon cable is damaged or disconnected. Your best shot is probably to replace that cable and reconnect everything you took off
这个答案有帮助吗?
得分 0
添加一条评论
I had this exact same issue, what I did is I changed the top screen, don't know why it worked but it did
这个答案有帮助吗?
得分 0
1条评论:
I have the same issue with 2 of my 2DS. Is there a solution found for this problem?
完成的
添加一条评论
添加你的答案
Michael garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 30
过去 30 天: 159
总计 9,181
