跳转到主内容
The HP Flyer Red is a laptop created by Hewlett Packard which was released around December 2014.
20 个问题 查看全部
How much can I upgrade the HP-r132wm model?
I have an HP 15-r132wm that's pretty much in mint condition, but it's specs are just a little under what I'd like. I've already got a RAM upgrade to install, but it's hard to find other information about this model.
Can I change out the processor and graphics card, or are they soldered to the motherboard? What's the maximum of anything I could upgrade this thing to? I don't need a beast of a machine, I just need it to be able to handle a little more than it can right now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @marzaura
Here's the maintenance and service guide, taken from this support webpage for the laptop.
It shows that there is only 1 ram slot on the motherboard and that the maximum ram module available is 8GB - PC3L (DDR3L), 12800, 1600-MHz SODIMM ram. You will have to remove the systemboard to get to the ram slot as it is on the underside of the board (see p.76 of the guide for the procedure)
According to the parts list for your model the motherboard is part #788287-501. so it has an N3540 CPU which has integrated graphics and it is hard mounted on the systemboard. There is no separate discrete GPU
To improve performance you should be able to upgrade the sata HDD up to a 4TB 2.5" sata SSD (if you need this much storage) without too much trouble. You won't even need a spacer under the SSD to ensure the SSD lines up with the connector as the parts list specs show that it is a 7.0mm HDD in the laptop and most SSD are also 7.0mm in height whereas some other laptops have a 16.5mm sata HDD, so a 9.5mm spacer is required to be placed under the SSD to raise it to the requisite height.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alister 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 235
