跳转到主内容
Why is there no back glass replacement manual
Ik there's a lot replacement video for pixel 4xl back glass but it doesn't shows how to remove and apply the wireless charging coil Frome from the broken back onto the new one also the rear camera cover onto the new one, so i really need the manual and video for it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Azfar,
Apparently you missed the iFixit guide specifically made for removing and replacing the wireless charging coil for your phone. It's right here.
Google Pixel 4 XL Wireless Charging Coil Replacement - iFixit Repair Guide
I'm not clear what you mean by the rear camera cover; all the replacement frames I've seen online come with the rear panel already assembled with the camera mounting parts and lenses. I did note that the flash/microphone/sensor assembly needs to be moved over from the old panel to the new one; is that what you're referring to?
If so, I didn't manage to find any guides to that particular replacement, but I checked and it appears the standard Pixel 4's rear panel assembly is very similar so I'm fairly confident the available guide for that will be sufficient to enable you to replace it on your 4XL. Here's the guide.
Google Pixel 4 Flash Assembly Replacement - iFixit Repair Guide
Good luck with your repair; let us know how it goes!
Google Pixel 4 XL Wireless Charging Coil图片
指南
难度:
中等
10 - 30 minutes
Google Pixel 4 Flash Assembly图片
指南
难度:
中等
10 - 30 minutes
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Azfar Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 64
