跳转到主内容
苹果公司最小的iPhone 14于9月9日发布,配备了6.1英寸OLED显示屏,先进的双1200万像素相机系统,以及带自动对焦的前置相机。此机型取代iPhone 13。
Why does my iPhone 14 has a smudge on the display?
My Iphone has a smudge which can be visible mostly on grey screens and also can be seen on screenshots. This is weird, since i can see it in a screenshot i think it has some thing to do with software but I'm not sure.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
iOS 16.1.1 just released. Maybe you can try updating?
完成的
添加一条评论
3个答案
最有帮助的答案
Hi
It looks like it could be some form of
discolouration between the layers or the display
If it’s still in warranty it might be worth a shot taking it to apple to get it fixed under warranty however if it isn’t available you could replace the display to fix the issue
Here’s the guide for that
iPhone 14 屏幕替换
However if it appears in a screenshot it is a software issue and could be fixed by restoring the phone or waiting for a software update that fixes it
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
3条评论:
If it appears in a screenshot than it is probably not a issue for the screen.
完成的
@thequacker
I mentioned that in a edit :-)
I only realised it was a screen shot after I looked at it several times XD
完成的
@hellomacos No problem!
完成的
添加一条评论
Let's retrace:
  • If the issue is on your phone display but doesn't appear on a screenshot it is caused by a stain on the display, such as sauce.
  • If the issue appears on the phone display and screenshot it's a common problem caused by LCD damage or discoloration.
If it's the first issue grab paper towels and thoroughly clean off the display. If it's the second issue you have to replace the display screen either at home or at a repair shop. Just make sure your device still has warranty for qualified repair.
iPhone 14 屏幕替换
这个答案有帮助吗?
得分 1
添加一条评论
In my own experience, this could be a software bug. Please check on different software to see if the error appears on all applications, if it is always fixed at one point, then this is definitely a hardware error, now you need to bring the phone. this phone to an Apple service center for processing. In case of software failure, you can manually reinstall the new software.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alon Karaev 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 1,398
