跳转到主内容
Repair guides and support for the OnePlus 5T, an Android smartphone with a 6.01" AMOLED display. Released in November 2017. Successor to the OnePlus 5. Model number: A5010.
35 个问题 查看全部
Newly-bought battery for OnePlus 5T does not charge anymore
Hey there,
I've recently bought a replacement battery for my 5T.
The replacement process went well, and all worked fine(for a bit).
On the packaging(and here) it says to charge the battery to 100% and keep charging it(which I did), let it drain completely, and then charge it back up.
Now, I did the charge up to 100% + the extra 2 hours yesterday, where everything worked fine.
I let it drain over the course of today, and plugged it in when the phone shut down, just as described.
Since then, it hasn't been charging, and keeps showing the screen described in this post, which incidentally was the very reason I bought this replacement.
What's happening? I'm confused, the charging worked just fine yesterday, so the charging plug shouldn't be the problem. Did I just get unlucky and receive a broken battery?
Thank you very much for any help/suggestions!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Anything is possible == bad battery, bad charging circuit, loose connection for the sense info from the battery to the charging circuit, bad charger or bad cable. Do more troubleshooting.
这个答案有帮助吗?
得分 0
1条评论:
How should I do the troubleshooting?
I've already tested different cables and chargers, but I don't just have spare charging circuits, obviously.
Should I return the battery and try anew with a different one? Or do you think buying a charging circuit and trying it out would make more sense?
Thanks for your answer!
完成的
添加一条评论
添加你的答案
a confused Buyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 92
