跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
Can not identify part (battery replacement tutorial)
So I was following the tutorial for battery replacement for Surface pro 4. and when I was removing the motherboard. this part popped out (I think under it?). And I am obviously stuck with reassembly. Can someone advise what is it and where to put it? Please?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
That is a support bracket for the heatsink. I'm assuming that the batteries that you replaced were swollen.
I was actually searching the forum today to see if anyone has a method of reattaching them. (I have a couple that also had swollen batteries.)
In addition to supporting the heatsink, it also transfers heat to the metal case.
You can use the Surface without it, it just means the thermal transfer will be diminished.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aleksandre Akhmeteli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 77
