跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Why is my screen not responding to touch?
I have been trying to fix my iPhone (6 s plus) with no avail. When I press a button the screen displays things, but the screen doesn’t respond to touch input. Restarting the phone doesn’t work either nor does replacing the screen. I also didn’t have Siri on so I can’t unlock the phone to connect to iTunes. The screen stopped working when I changed the battery and because the initial battery was applied with glue, I used to much alcohol trying to remove the glue. I only want the data on the phone. Is there a solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi akwardllama1234,
Unfortunately, you need to (at the very least) open your phone up again. Disconnect the battery first, then disconnect the screen. Clean the connectors with >99% isopropyl alcohol before reconnecting in reverse order. Test to see if touch functionality is restored before closing up the phone.
If the clean and reseat doesn’t fix it, you’re looking at a screen swap, to be able to get touch working so you can recover the data. There is no way to get the phone connected to a computer and authorizes for backup, without touch functionality.
The 6 / 6 Plus phones had something called “touch disease”. This was because the touch IC on the logic board failed. Not applicable to 6S and above, because the IC is no longer into logic board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
akwardllama1234 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 30
