跳转到主内容
本指南适用于联想 Edge 15 笔记本电脑,型号为 80K9。联想 Edge 15 于 2014 年 8 月发布。
Why is not starting it's not taking charge not showing starting light
My laptop is not starting, working
My laptop doesn't show starting light
It's not taking power
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @nilsarg,
What is the model number of the laptop as shown on the information label on the bottom of the laptop?
This is so that if any replacement parts are required then the correct ones can be found
完成的
添加一条评论
1个答案
Without more info, it could be a bad battery, a bad charger, a bad power socket, or a bad charging board/circuit.
The laptop should run with just the charger. If not check charger, socket, motherboard. If it runs, check/replace battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nisarg sharma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 126
