跳转到主内容
加入维修社区 - 创建账户
A mid-range smartphone from Samsung released in 2019.
Bluetooth does not work after replacement
This phone has faced various difficulties. First it went into the water, and then shortly after having it repaired it fell on the ground. After this latest incident, I decided to repair it myself. I will preface this by saying that I was not using the phone (it may be that there were already problems but the user was not using bluetooth).
I changed the battery, display and front camera. Now everything works except the bluetooth. It doesn't always connect with devices, at best it connects but works poorly. For example, if I connect headphones, those few times I can connect them, it is jerky and I can't get too far away from the phone. Any recommendations?
I leave attached photos of how I assembled the phone:
https://drive.google.com/drive/folders/1...
One question: is there a possibility to change a bluetooth card or is it built into the motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like a corrosion issue from the liquid. Open it up again, remove the motherboard and check for signs of corrosion. You might have to remove a few plates too.
这个答案有帮助吗?
得分 0
5条评论:
I don't know how to tell if there is corrosion, could you help me? I am attaching photos of the motherboard
完成的
@most99 you’ll have to remove the plates covering the rest of the board especially the black one with the patch on it.
完成的
https://drive.google.com/file/d/1ycRawbO...
Do you mean the one I've outlined in red? Can you tell me how to remove them and what to do after that?
完成的
@most99 yes, and any on the other side too. They can hold moisture.
完成的
Since I'm not yet an expert and I'm afraid of messing up (so far I've only replaced displays, batteries, simple things), could you tell me clearly how to proceed? You would be a great help to me. I haven't worked with delicate things like the motherboard yet. How do I remove these plates? What to do once they are removed? Should I clean them or what else? Thank you very much.
完成的
添加一条评论
添加你的答案
Gavino Santu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 202
