跳转到主内容
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 个问题 查看全部
Is there heatsink hold-down pins replacement?
I was wondering I broke one of the heatsink hold-down pins in my mid-2007 Mac mini and I was wondering if I can use a metal screw that’s a 4-40 3/4 screw to replace the plastic pin? Or if not do I need all four or can I just use three pins instead of all four pins?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
This is a bit of a sticky situation isn’t it!
It is important that you have all 4 as that will apply even pressure to the die of the chip as in even pressure can crack is in half and kill the chip instantly
I would buy a new heatsink to be on the safe side but if that isn’t possible I would use 2 pins that are diagonally on ether corners of the heatsink to apply even pressure (refer to image below)
You can use the ones circled if you would like
As for the idea of using a screw: I wouldn’t do that as it would be hard to control the pressure as the heatsink east designed for it
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
2条评论:
So but just using two of the corner pins it won’t hurt the cpu. And ones that are circle I broke one that is circle. And will it be alright to use a zip tie to replace the one that’s broken? Or can I use the others two pin on a different corner?
完成的
@Jordan Chapman
It shouldn’t hurst the cpu as long as your careful
As for the broken pin,it doesn’t have to be the same ones as in the photo, aslong as they are diagonally opposite it should be fine
I wouldn’t use a zip tie as controlling the pressure would be difficult:-)
完成的
添加一条评论
添加你的答案
Jordan Chapman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 93
