跳转到主内容
一款任天堂为 Switch 系统生产的无线、经典的视频游戏手柄。型号:HAC-013。
Motherboard is missing a component which stopped battery from charging
I was installing a new potentiometer and I accidentally knocked off a small piece off the board, the part is labeled UP0KC or UPOKC I'm not sure which, but there's a picture of it. I'd like to know where I can find it and if I can't find it how it works and if I can bypass it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You could bridge cables if you know how to solder properly like tronicfix or you’d have to get a new fuse somehow
这个答案有帮助吗?
得分 1
4条评论:
It's a Fuze then?
完成的
And if I were to bypass it how would I do that considering it's 2 prongs to 3.
完成的
Ah never mind over more carefull inspection of the image it looks as if its a smaller chip
完成的
And im not sure if it can be bypassed like so you’d probably have to replace it
完成的
添加一条评论
添加你的答案
Gabriel Logulo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 96
