跳转到主内容
Second generation of the Ford Focus.
94 个问题 查看全部
Can I remove the hub and wheel bearing together when removing them
Can I remove the hub and wheel bearing together when removing them on front drive side it shows people removing bearings first then hub I'm buying the hub and bearings together and it shows both being put on together I have 2005 focus
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There is an outter and inner wheel bearing the bearings will sometimes slide off with the hub or rotary, a sometimes they are pressed on the axel or spindle. Usually the outer will side of with the hub or axel, the inner bearing is the one that may be more difficult!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Trina Orrico 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 10
