跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 触控转盘
Why won't my center clickwheel button work?
My ipod 4th gen was working fine until about a week ago until the center button became unresponsive, The play, skip, and menu buttons all work fine, I am unsure about what the problem is that is happening, does anyone have any solutions, or things to check to see are broken?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
The best thing you can do at the moment is use this guide to disassemble the iPod and check things out from the inside
iPod 4th Generation or Photo Front Panel Replacement
Check that the click wheel connection are seated correctly and are free from dirt or debris(if there’s is any some isopropyl alcohol and some cotton buds is a good cleaner)
If cleaning the connectors doesn’t help you will most likely need a new click wheel or top case
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nik Rossi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 228
