跳转到主内容
Why can't I turn my computer on?
Hi,
I have a Sony VAIO VPCSC31FM than runs Windows 10.
Today when I was getting on my laptop, it wouldn't start. The orange light next to the arrow pointing to the battery icon was on, and the brick was also on.
When I pressed the power button, it didn't work.
Does anyone have a fix for this?
This laptop is about 10 years old and used to run Windows 7 Home Premium.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Start at the beginning >> the brick, and verify there is the specified voltage on the connector. When the brick is plugged in, it should run the computer even if the battery is bad or not installed. If it does not, then there is an issue with the socket on the computer or the power button circuit. The former being much easier to fix than the latter, but it must be opened up. You might not want to attempt that, and professional help will probably be economically not warranted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dominic Ruiz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 208
