跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
164 个问题 查看全部
Screen is dark after replacement and face id not working
I replaced the OLED on my iPhone 12 and the screen is super dim and i am unable to adjust it to be brighter it is just stuck. the face id has also stopped working. what do i do here? is there something i can fix without costing me a lot of money?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
when you swapped the flex over from the old screen to the new screen was there anything covering the front lens on the back of the new screen
这个答案有帮助吗?
得分 1
添加一条评论
It’s your ear speaker ribbon causing the problem. I’ve just had one with exactly the same issue. Disconnect the battery first. Then disconnect the ear speaker and screen ribbons again. Reseat everything then see if it works.
这个答案有帮助吗?
得分 1
添加一条评论
Have you updated your phone to ios 16 before you did the repair?
If so you will have to flash it back to ios 15 for any screen replacement to work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ashton Grabow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 128
