跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
132 个问题 查看全部
The sound on loundspeaker not loud enough
After replacing my first charger port on iPad 6, the sound on loudspeaker is not loud enough. Is replacing the charger socket affect the loudness of sound? Is there anyway I check it?
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Viet,
First of all, congratulations on a difficult repair; that charging port replacement is something I'd definitely have second thoughts about attempting!
Going over the steps required to pull the motherboard, it appears you have to unplug both speakers as part of the process. My strong suspicion is that one or both of the flex cables connecting the speakers to the lighting flex may not be fully seated. With those ZIF connectors you can't always tell for sure the cable is fully seated. If it was mine, I would open it back up again and reseat the speaker connectors.
Unfortunately, both of those speaker cables are ultimately routed through the lightning flex, so if reseating the speaker cables doesn't help, the the next obvious source of problems would be the solder job on the motherboard. Ouch, hope that's not it, so check those speaker ZIF connectors first.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Viet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 12
