跳转到主内容
加入维修社区 - 创建账户
第二代 Sony PlayStation 5 DualSense 手把的維修指南、拆解說明與故障排除資訊。 可透過型號 CFI-ZCT1W 及主機板型號 BDM-020 進行識別。
Not charging at all
Controller does not charge at all, ps5 recognizes while it's plugged only. There's a pending update I cannot due to low battery. I've tried different cords, back port, reset, deleted accesory, ps5 rebuilt database, update software with pc firmware. Playstation support agent said buy another one. Since out of warranty I opened and unplugged battery and reconnected, no changes at all. Any other idea or suggestions??
(My other controllers connect and charge in the additional options that I've tried in ruling out what is wrong with this controller.)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Jose,
So do you have another DualSense v2 controller besides the one that's malfunctioning? You mentioned that you've unplugged the battery; is it feasible for you to swap in the battery from one of your other controllers to see if the battery is causing your problems?
Putting in a known good battery would let you differentiate the problem between the battery itself and the charging circuitry inside the controller.
If it works fine with the other battery, then you're done; you'll have to locate a replacement, but that should take care of it. If not, then we can work with you to diagnose what else might be going on.
Check it out and let us know what you find.
这个答案有帮助吗?
得分 0
2条评论:
I have warranty on current controllers I own...I just ordered a new battery and will update this weekend
完成的
@joel84rt sounds good; that's the first thing I'd try myself. I'll be curious to see what happens.
完成的
添加一条评论
添加你的答案
Jose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 448
