跳转到主内容
加入维修社区 - 创建账户
Suzuki Swift 是日本汽车制造商 Suzuki 生产的一款小型车。第二代 Suzuki Swift 于 2010 年 9 月推出,并于 2017 年 2 月被新一代车型取代。
I loose power when accelerating and sometimes when in traffic
Intermittent stalling immediately after starting or punching gas. Sometimes also in traffic. I have tried changing the CVT, testing sensors, What might be the issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sounds like a fuel injector issue. Could also be a vacuum leak.
这个答案有帮助吗?
得分 1
2条评论:
I have to check this...But how would I check a vacuum leak ?
由完成的 分享
That is difficult unless it is a big leak and you can hear it. Disconnecting or pinching off vacuum lines might give a clue, but that involves much understanding of what you are affecting. My bet is on the injectors.
由完成的 分享
添加一条评论
Hi mate. Did you fix your problem?
What if your throttle was clogged?
这个答案有帮助吗?
得分 0
2条评论:
I've fixed a clogged catalytic converter that did something like this. I drilled a 3/8" hole in it.
由完成的 分享
might be fuel filter also that need to be cleaned or replaced..
由完成的 分享
添加一条评论
添加你的答案
William Afrika 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 33
总计 1,227
