跳转到主内容
A2115 / 2020 / Processors from 3.1 GHz 6-core i5, up to 3.8 GHz 8-core i7. Released August 4, 2020.
Why time machine backup more space I need?
Tried to use my new iMac desktop and transferred all my data and app from the old MacBook Pro laptop. Used time machine to do a full backup on my external hard drive, and it shows the backup size is less than 100GB. Then use “migration assistance” tool to do restore on iMac, but shows not enough space for restore. I have 250GB storage equipment on iMac and have a fresh Monterey installed, so, it should be well enough for this migration, right? I tried to use Diskwave tool to check library further and found “one drive” reported over 169GB space occupied, that’s weird as this is online app, it should not use my local hard drive space, isn’t it? I then exclude it in time machine menu and redo the back up, however, it still reported the same error. I attached some pictures I took, can someone give some clue what I could do wrongly here? Many thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Try putting your data on an external hard drive and plug it in to the new iMac u can acssess the data externally or just transfer it all! Good luck!
这个答案有帮助吗?
得分 0
1条评论:
Yeah, I can do data restore manually in this way, but my question is still, why "One drive" occupies space on local drive, and why I can not exclude it from backup on time machine?
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 249
