跳转到主内容
My battery is not being read correctly
It says 16% but its actually at 1% or dead, the batteries are not swollen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @nytryder26
Just because the battery is not swollen, that doesn't mean that it is not faulty or hasn't failed.
Try replacing the battery and then check.
You need to start with a known good battery rather than trying to find a problem in a device with a battery which may have an unknown problem, still installed.
If you get the same result with a new battery then the problem is not the battery
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the help!
完成的
添加一条评论
添加你的答案
NR26 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 245
