跳转到主内容
PlayStation 3 Slim是Sony Computer Entertainment生产的PS3视频游戏机的第二版。 它于2009年9月1日发布。
465 个问题 查看全部
Ps3 slim blu ray laser replacement
OK so i used the video posted to here from consolezombie to replace my blu ray lens. disassembly was great no problems at all. my problems began with reassembly. while it should be easy enough to just reverse the steps, i had a group of different problems when attempting. I cannot insert discs now due to a white piece of plastic which is on a spring on the bottom black plastic piece of the drive. it blocks the discs from going in. i once accidentally had it down, reassembled it all, and then my ps3 wouldnt register the disc, then wouldnt eject it, and then when i manually took the disc out, the plastic piece went back to where it was. if anybody can post or find a detailed reassmbly video or manual for the ps3 slim blu ray drive, i would very much appreciate it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
This is a pretty good tear down guide...you will just have to start at the end and work backwards...while you are in the blu ray drive i believe you will have to reset that plastic pin you are talking about then reassemble....also make sure that the plug for the disc sensor is plugged in...it is a very small plug with a black and a red wire going to it.
Hope this helped,
Cody
这个答案有帮助吗?
得分 1
添加一条评论
did you forgot to insert a disc inside before it was apart.. it will keep things in place.. sometimes using a cel phone to video your moves will also help.. i have a photographic memory when it comes to electronics, but sometimes there is too much to keep track of.. i know this is too late, but for us fixer uppers this will not be the last time we explore to repair the unknown..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Casey Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 10,777
