Sensing turns on and drum spins very slowly 2-3 cycles before it goes
I have a similar problem with our MVWB65FW3 commercial washer. I start the washer, light on Sensing turns on and drum spins very slowly 2-3 cycles before it goes to Wash cycle but immediately stops and returns to sensing. Repeats this cycle 4-5 times before it finally turns off. Takes a while before Lid Lock releases.
2条评论
Did you ever finf out how to fix your washer, im having the same problem. I havr the same model as yours
由 Sandra Gonzalo 完成的
@sandragonzalo
What does performing the diagnostic tests show, if anything? See the Most Helpful Answer below.
由 jayeff 完成的
