跳转到主内容
trackpad doesn't work properly after installing new top and keyboard
Have a MBA 13" 2014. Keyboard was bad, so bought a new top with the keyboard, exchanged everything into the new case and used the same trackpad and cable from the operating unit (same motherboard, etc. ) now the trackpad doesn't work correctly (no click select, scroll ok. Cable is connected correctly, it is the same trackpad and cable and motherboard... Issue? tried reseating both ends of the cable, no difference. Any ideas? Di all the usual stuff SMC, NVRAM, etc.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi
Hopefully this issue isn’t a board level issue or a cable/track pad issue
When things like this randomly stop working properly I find cleaning the connectors(both board and cable) with some isopropyl alcohol
I would also pay close attention to any “dull”looking pins and if any are sound throughly clean them
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
7条评论:
Thanks, Yes, I did that and got a different operational result, so ordered a new cable. Looked under scope and the one (that was part of the system was looking OK0 The user then told me her trackpad had not been operating properly for sometime. Hmm. So have a replacement on order. Always ask all the questions first to see if there is something else going on... HA. The new top & keyboard (original repair) operate fine., Thank you.
完成的
@macman67
Your most welcome
Please let me know if there is anything else
完成的
Tried cleaning, then ordered a new cable from Beetstech.in Chico, CA Alls well, Thanks.
完成的
@macman67
That’s great!
Did you install the new one or are you still waiting to receive the part?
完成的
Got the parts the next day and installed, works like new.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Carl Schultz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 141
