跳转到主内容
加入维修社区 - 创建账户
型号A1288,闪存容量:8、16及32GB
iPod touch home button replacement?
I had replaced my Ipod touch 8gb 2nd generation digitizer with a replacement because I had cracked the screen. The home button worked before removing the digitizer so I than replaced touchscreen works excellent but the home button does not work. So is it the digitizer ribbon not being in proper place or something or is it a faulty screen/home button? If you can help it would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Not in the shop right now, but if I recall correctly, on under the home button on the board there is "s" shaped copper connector sticking up. When you press the home button, it presses this connector down. Use a plastic pry tool and "gently and slightly" pull up on the connector. In other words you want to shape it from "s" to "S", just slightly taller.
What happens is the "S" connector gets pushed down too much towards the logic board and when you press the home button it can't make contact.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Corey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,384
