跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
Mouse/trackpad freezing every 3 seconds for like half second
Hi guys,
I have MBP 2019 and if I am working mouse/trackpad freezing every 3 second for like half second - it's really annoying (specially in Photoshop). Yesterday I made update to macOS Ventura but still same issue.
Thanks for any advice/ideas.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi
Have you tried reseating and cleaning the trackpad connection on the logicboard
Here’s the guide you will need
带Touch Bar的2019年13寸MacBook Pro 2019 触控板更换
Also have you tried a wired or wireless mouse to see if the behaviour persists?
If a different mouse works fine and reseating it doesn’t work it could mean that the trackpad or the cable is faulty and needs replacing
It could be a logic board issue but that is quite unlikely but not off the table
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
5条评论:
It’s probably motherboard issue as I noticed that one of the USB-C also not working :( I don’t know the history of this MBP but after issue with UCB-C I am done with this because I don’t know what else can be damage.
完成的
But thank you for answer :)
完成的
@roboscrap
Your most welcome:-)
If you wanted to you could try and fix the logicboard you could but from what you said it seems like CD3215(usb controller chips that has failed,ether that or the usb port itself
But then there the other issue to fix too
But it’s entirely up to you
完成的
I will check logic board and will see :) again thanks a lot.
完成的
@roboscrap
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 224
