跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
Why my MacBook Air turns off Randomly
My laptop completely ran out of battery after 2 months of no use / no charging (I left it under the bed). When I tried to start it and didn’t work so I used the alt/shift/ctrl/power button technique. Took it a while but finally came back. Used it one day with no problems (plugged and unplugged) and the third day of use it started to shut down randomly (sometimes while loading the profile just after starting it). Is there any suggestion on what could be wrong or what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hi
When a device starts behaving like this it usually means that your batter is needing replaced
Leaving lithium battery’s sitting for a long time can cause them to degrade and stop working properly
Also the temperature and amount of battery cycles has a lot to do with it too
Here’s how to check your battery’s health(linked below)
https://www.coconut-flavour.com/coconutb...
If your cycles are above 500 and it says service anywhere that usually means that the battery is the issue
Here’s a link to the part you may need
MacBook Air 13" (Late 2010-2017) Battery
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
2条评论:
I really find this app makes the information easier to read and brings it together in a simpler presentation CoconutBattery the free version is only you need.
完成的
@danj
Thanks for the information!
Il add it to to my answer
完成的
添加一条评论
添加你的答案
DanCas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 67
