跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
MacBook Pro won’t turn on after battery disconnection
hello
i have a 2020 m1 macbook pro. i disconnected the battery and reconnected it, and now my macbook will only turn on when connect to the power adapter. also the fax runs on max when it’s on. could it be that i haven’t reconnected the battery correctly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
13条评论
Restart your system and press the D key to enter into the system’s onboard diagnostics, let us know what the erro message is.
完成的
@danj sadly i can’t get into diagnostics
完成的
@Majd D
For a apple silicon Mac you need to press/hold command(CMD ⌘) + D at start up/restart
That should get you into the diognostics:-)
完成的
@hellomacos - Yep! Had Intel on my mind. Thanks for catching that.
完成的
@danj
No problem
It happens to me all the time XD
完成的
显示更多的8条评论
添加一条评论
1个答案
最有帮助的答案
This sounds to me like the battery data cable is not connected quite properly, or your battery is faulty. This is pretty typical of a sensor not communicating toThe MacBook Pro Battery has 2 battery connections. The first is the small cable and the second is the large T5 screw, which forces the actual power connections. I would verify the cable is seated properly on both ends, and that the little latch holding it in place is present, and closed.
这个答案有帮助吗?
得分 2
3条评论:
that’s what i was thinking. but after making sure it’s connected dozens of times i’m not convinced i short circuited it :(
完成的
Hi! Could you tell me how you solved it?
完成的
In my case the data cable got damaged during disassembly, I ordered a replacement and that fixed it.
完成的
添加一条评论
添加你的答案
Yyy 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 29
总计 1,718
