Battery Not Charging and Computer Won't Run on AC Power
just bought a refurbished Panasonic Toughbook CF-53 a while ago, and while it's working well enough so far, as a couple hours ago the battery has mysteriously stopped charging.
When I plug the adapter in, the battery light turns yellow, then starts flashing red about thirty seconds later. I have no clue why it does this, the most intuitive answer I can think of is that the battery died, but I have no idea why it would die so suddenly.
It was on something like 14% charge and charging while plugged in last I checked, but now ot just won't work, and since the computer can't seem to run on AC power alone that means it's bricked until I can figure out how to fix it.
The only thing of note that I can think of that happened before the battery failed is that I was playing AdventureQuest that seemed to cause the computer's fan to start running really hard. The game isn't particularly graphically intensive though so I can't see why that would do this to the battery
Any advice?
4条评论
Did you take the battery out when you tried just using the charger?
由 mike 完成的
@aactech I did, yes. The computer won't turn on at all when the battery isn't inside, even when the AC is plugged in.
With the battery inside it will boot briefly but then immediately shut down
由 Zenn 完成的
I am having the same issue with mine tonight. Were you able to find out what was causing it? Is it needing a battery replacement?
由 Charlotte 完成的
I have this problem too.....but i bought a brand new battery. The new battery came with 70% charge and my computer is not charging it. The yellow charging light flickers then goes solid for a few seconds then flickers. It seems the computer is not charging it while its in the computer. Are there battery chargers that i can buy to charge the battery separately outside of the computer?
由 Patricia Pettigrew-Johnson 完成的
