跳转到主内容
加入维修社区 - 创建账户
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
Why won't my phone turn on after replacing screen?
I replaced the front screen, and it won't turn on. Could it be the charging port is damaged? Could it be the battery? Could it be the motherboard? I tested two screens, so I know it is not the screens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Out of curiosity, was replacing the screen the first thing you did to try and diagnose the problem of not turning on, or was there another reason and the phone was turning on previously? How did it start; did anything change recently such as an IOS update, or any kind of damage like being dropped, getting wet, etc.?
As @tomchai mentioned, there are unfortunately a lot of different reasons why a phone doesn't turn on. Do you get any kind of indication such as a chime or vibration when you plug in a charger? You've tried different chargers and cables, right?
Go through this troubleshooting guide and see if anything there helps. If not, come on back and add the information on what you find to your question and we'll see what we can do to help.
iPhone Won't Turn On - iFixit
Good luck; let us know how it goes!
这个答案有帮助吗?
得分 2
添加一条评论
Could be anything, you swap the parts to find out.
这个答案有帮助吗?
得分 1
添加一条评论
i change the screen, first time the new screen can turn on, but when I restarted it again, it cann't work, but I can sure the battery is ok, bez the scilent button is work well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
B P 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 310
