跳转到主内容
加入维修社区 - 创建账户
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Panel Discoloration from Goof Off
I'm currently working on a battery replacement and had to resort to using Goof Off vs. the Adhesive Remover that came with the new battery (I'm not that strong and needed something heavy-duty.)
After removing the old battery, I started working on the leftover adhesive and I got Goof Off on a part of the panel I wasn't intending. Now it's discolored. Should I be concerned?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
@theshadow7x Could you point out the part(s) that concerns you? I can’t really see anything in the picture you attached, that I would be concerned about.
完成的
@geirandersen Attaching a cropped and highlighted picture.
完成的
@Sean Foden Thanks!
完成的
@theshadow7x Just an FYI; That post above is just covert spam. Have been seeing that a lot lately :(
完成的
添加一条评论
1个答案
已选择的解决方案
@theshadow7x Sorry for the late reply; Timezones and all that..
The marks you’ve circled appears to be hard scratch marks, made by a hard tool in scraping? I wouldn’t worry about it personally, if it was on my own device, but I would repair on a customer’s device.
这个答案有帮助吗?
得分 1
4条评论:
@geirandersen No worries! I appreciate the assistance! It was done by the adhesive remover I used. If it were you, how would you go about repairing that?
完成的
@theshadow7x Well, you could try and replace the "sticker" / film, if you can find a source for the part. I can't remember where I saw it last, but I have seen it online.
完成的
Thanks for the info! I'm replacing the battery for a friend and I showed him what happened. He said it wasn't worried about it.
Thanks again for your help!
完成的
@theshadow7x That my friend, is EXACTLY how you do it! If you make a small unimportant mistake like this, and there's really no reason to repair it; Owning up to it and showing it to the owner for him/her to decide, is 110% the correct way to handle it.
We can all make mistakes, that's just how life is. A good person owns up to it and discloses or repairs, whilst a dishonest person would cover it up and try to "get away with it".
完成的
添加一条评论
添加你的答案
CKN 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 9
总计 213
