跳转到主内容
The model guitar that we are using is a "Starcaster by Fender". It is an affordable guitar that is commonly sold in big box stores. The body style is based off of the "Fender Stratocaster", and is not the same as the similarly named "Fender Starcaster" semi-hollowbody.
1 个问题 查看全部
How to replace snapped far e string
About 1 month ago, I was playing guitar and I bent the e string too far and it snapped. I was asking how I could do it myself and get a guide to do it myself. If anyone has a guide that they can lend that would be good.
The closest guitar I could get was a Fender stratocaster but the guitar is a westfield guitar.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
To restring most guitars you will need to slacken off the strings by turning the pegs ant the top for each string
Once you have the string slackens you will need to have a look for the little peg/catches at the bottom that help hold the string in and pull it out so that you can replace the string
this can vary from guitar to guitar so here's a video that is hopefully some help
https://youtu.be/4CtqfHmssx8
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mackerel25 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 79
