跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Why is my phone not responding to anything?
The phone is not responding to any input. I tried plugging it into the power, but nothing happened. I tried force resetting it, but with no response. Please help, I've tried everything I can without opening the phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Kuba,
Top of the list is to make sure your phone is getting power. You've tried different chargers and power cords, right? Wiggled the plug when it's inserted? Checked the charging port for dust, dirt or debris and cleaned it with 90%+ isopropyl alcohol? Examined it with a magnifying glass and a bright light looking for bent or missing pins?
So what was happening with the phone before it died? Has anything changed? Updates installed, phone dropped, got wet, run over by a snow plow, etc.? Has it been charging correctly up till now? Battery life normal?
Give us more detail on the history of the phone, because right now we don't have enough information to be able to help you.
At some point you're most likely going to have to open the phone, so you might want to order some tools and display adhesive so you're ready when the time comes.
这个答案有帮助吗?
得分 1
2条评论:
About the history of the phone, i was my old daily driver, that i recently found in the attic. I don't remember if the battery was fine then, but i remember that it has the latest supported iOS version.
完成的
@qulek34, Ah, that helps. Well, after sitting for so long and probably getting hot if your attic is anything like mine, I'd say there's a very high probability the battery is totally shot.
The good news is that for old iPhones like yours, parts prices have dropped exponentially so you should be able to pick up a replacement battery for a song. That's what my next step would be if it was my phone.
And yes, I still have my wife's old 5C around too. Had to replace the screen after I got it back from my brother borrowing it, but it still works just fine. Well, outside of the fact that Verizon won't let me activate it on their network any more, that is.
完成的
添加一条评论
添加你的答案
Kuba Owczarzak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 102
