跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
Why isn’t my iPod turning on?
I have an iPod touch 4th generation that does not turn on, and the screen will will turn white for as long as I hold down the power button, then go dark again, wondering if there is any easy way to fix it, or if it requires board repair.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Check that you have firm cable connections. Remove any debris from all ports. Try a different charging cable, power adapter, and power source. Don't use an adapter or cable that shows any sign of damage.
Regards,
Will
这个答案有帮助吗?
得分 3
添加一条评论
It's old now, try turning it on with the charger connected. If not, try a new battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
someguyidk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 169
