跳转到主内容
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
114 个问题 查看全部
PAL N64 Displaying Weird Colours
Hello
My unmodded PAL N64 was working fine on my Sony Trinitron last year via an S-Video Cable and Scart Adapter purchased from Console Goods.
I’ve set it up this week and have ran into an issue.
The graphics are unplayably dark with strange inverted colours when the TV is set to standard AV mode and when set to RGB, the picture is crystal clear but all red! I know a PAL N64 can’t display RGB without a Mod but i was frustrated by how good the picture looks. Much better than the photo conveys.
I’ve bought another cable and Scart adapter, tried different games, cleaned cartridge slot and games with rubbing alcohol/cotton bud sticks. I hooked it up via RF and via composite cables. And also hooked it up to my Samsung 4K tv via composite.
Still the same
The dark AV image
The Red RGB image
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Check the connection ports on the back or side of your TV for a component input. This connection has 5 ports: green, blue, red, and red and white ports for audio. If your TV does not have a component connection port, then you will need to use a scaler
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Biddlestone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 220
