跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
555 个问题 查看全部
Hard start, will crank and run only with choke
I’m having the same issues. Hard start, will crank and run only with choke wide open only then suddenly dies. Adjusted valves, new starter gear (slightly worn…possibly the numerous times trying to crank it), when preparing to adjust valves, I can hear the cam mechanism click when exhaust valve reaches dead center. Only option that I have left is new spark plug, fuel filter, check choke position to ensure it’s operational and give it a good washing. This sometimes it’ll crank easily or the continuous issue of it’ll start today or not is difficult to pinpoint the exact problem is beginning to be a nightmare.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would clean out the whole fuel system, including the float bowl and use fresh non ethanol gas. The fuel pump and filter are pretty cheap and easy to swap. My Craftsman was actually missing a gasket in the intake manifold area; this was fuel air mix and I had to choke to get a steady idle.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Haircare1954 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 64
