跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
210 个问题 查看全部
My Wifi is Greyed out, How could I fix it?
I have tried a reset and done everything WiFi works over Bluetooth using my iPhone but is very slow, It used to work just fine but now it doesnt it is a 16GB iPad Air 2.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Why hello Xavier. Trying to fix your iPad lol The wifi antenna might be bad.
完成的
添加一条评论
2个答案
最有帮助的答案
This will not be an antenna issue. If the Wi-Fi is greyed out you defiantly have a board issue. You will need to check that the Wi-Fi chip is getting power, if it is you will need to re-ball or replace the chip. If it isn’t getting power you will need to find the faulty component that has failed. Microsoldering will be needed to fix this problem.
这个答案有帮助吗?
得分 4
1条评论:
UPDATE: I just plugged it in and powered it on for the first time in a month, Wifi is back so I think it keeps getting overvolted or something like that.
完成的
添加一条评论
It sounds like it could be an issue with the Wi-Fi Antenna. If you follow this guide to check the state of the antenna. I would attempt to reseat the antenna before attempting a replacement. Otherwise, it sounds like it could be an issue with the logic board.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
添加你的答案
Xavier K 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 758
