跳转到主内容
The OnePlus 8 Pro is an Android smartphone from OnePlus. It was Released in May of 2020.
10 个问题 查看全部
Why is my new battery going dead in minutes?
I purchased a battery from ifix it because I thought it would be better than saving money and buying from Amazon. Ever since I installed it my battery life has been FAR worse than before I replaced it. The phone will charge to 100% only to fall to 20% I'm under 5mins and then from 20% to 0% it will go down slower but not as slow as I would expect. I think that the phone is misreading or something and thinking the battery is full and not charging all of the way because it says 100%. Any help is appreciated 👍.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi
It could be a faulty battery
However
It could be that the battery needs recalibrated as new battery’s need to “learn” how to read their percentage properly
I have had loads of them that act like this and it’s usually that or the battery connector just needs reseated
I would try charging it up fully then draining it till flat a couple times to help recalibrate it and if the issue persists contact iFixit to see about getting a replacement or a refund
iFixit support is great so they will make it right:-)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
2条评论:
Ok cool thanks for the help, since I already tried doing this calibration process I'll go ahead and contact ifixit.
完成的
@sauce_boss
That’s the best thing to do
Iv contacted them before
They are amazing and they will make it right:-)
完成的
添加一条评论
Same issue, I thought ifixit would have best quality and I received different one than it was on the photo.
Drains faster than my 4yo used battery. Can't return it...
这个答案有帮助吗?
得分 0
1条评论:
@itsmrdope I suggest you get in touch with the iFixit Store personnel and let them know what's going on. Their batteries have a 1 year warranty and whenever I've dealt with them they've been responsive and helpful. Best way is to email them at support@ifixit.com
@krisrodriguez, a heads up on Mr Dope's issue here.
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 40
总计 737
