跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
399 个问题 查看全部
iPhone XS going off
I try Good day, trust you re good . Please I recently changed my IPhone XS battery and phone screen. I changed the battery because it was on service and it was swollen, also changed the screen because it was cracked. I notice after the replacement, my phone keep going off, it only comes on and work properly when the screen is not screwed to the phone. The moment I try putting the screen properly to the phone by screwing it then my phone goes off, it only comes on again when I detach the screen from the phone . Please what could be wrong
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Abdulkareem, it sounds like something isn't seated properly and is being bent/pulled out of place when the pressure of the screen is put on the innards of your phone.
I'd recommend to check all of your connectors to make sure everything is snapped shut, seated straight, and not loose. You can use this guide to double check all connections.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Abdulkareem Ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 66
