跳转到主内容
电脑制造商联想所生产的台式机的维修和支持指南。
97 个问题 查看全部
What does the pins do?
I am moving my legion t530-28icb to a new chassi. But when I look on the motherboard I can figure it where power, reset, led and hdd led goes. I now sort of what clusters of pins, but I don’t know what pin is minus or plus or whatever. The board doesn’t say.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Which header pins do you mean?
If it is for a fan or a LED light, then if they're reversed, for a fan it will run in the reverse direction (or not at all) so maybe sucking air in rather than blowing air out and if a LED light then it won't turn on
Here's the hardware maintenance manual that shows what and where all the motherboard connections are, although admittedly not how to correctly connect to them. Go to p.22 and the top of p.23 for your particular model motherboard.
这个答案有帮助吗?
得分 1
3条评论:
The pins for the front panel, power button and so on. And the manual does not show what each separate pin does. And I can’t connect them without that info.
完成的
@Peter Lönn
here's a link that may help if they're wired the same way for the panel headers that is. Maybe try just one connecting one pair of wires first e.g power button wires or HDD LED wires.
If no good you may have to find the schematics for the motherboard to find out what each pin does.
What is the motherboard's make and model number which is usually printed onthe board?
完成的
@Peter Lönn
Here's a link to the schematics that should help.
Unfortunately you have to buy it, but at least it might take the guesswork out of finding the pin layout.
完成的
添加一条评论
添加你的答案
Peter Lönn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 248
