跳转到主内容
加入维修社区 - 创建账户
The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
Error message F5 E3
Washer lid will not unlock. How do I fix or bypass and is that my only issue? Seems like the F5 E3 code could also be another problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @appliancedummy,
Please confirm the model number of the washer?
Just in case the reset below doesn't fix the problem.
完成的
添加一条评论
1个答案
The F5 E3 alert indicates there is an issue with the lid lock. Do not force the lid open, as permanent damage could occur. Remove any objects from the lid and clear any obstructions. Touch POWER to exit the cycle, then touch POWER again to release the lid.
Regards,
Will
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Appliancedummy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 1,820
