跳转到主内容
Repair and disassembly information for Samsung's flagship S20 FE Android smartphone, released in October of 2020. Identified by model numbers SM-G780F or SM-G780F/DSM
31 个问题 查看全部
S20 keeps saying moisture detected when a non-Samsung charger is in us
I just discovered recently that when I try to charge my phone with my MacBook usb-c charger it doesn't charge but immediately says moisture is detected and stops charging. It doesn't let's me charge with any other original Samsung charger after it. The port is not not wet obviously. And it happened with 2 different Mac charger. I usually "hack" my phone. I switch it off and start changing anyway. If I simply reboot it it doesn't help. Does anyone else have this problem? Can it be fixed? I would like to use other chargers too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I see this happen but in most cases it happens regardless of what brand of charger is used. The charge ports tend to have this issue. Luckily it's a fairly easy fix. Replace the charge port.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
medeaeva 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 146
