跳转到主内容
The Oculus Touch Controllers (2nd generation) are 6DOF virtual reality controllers used with cameras that track infrared light emitted from the tracking ring.
3 个问题 查看全部
Where to find and how to replace the infrared led array in the ring?
So whenever I was fixing a stuck button on my left controller i managed to tear one of the it sensors off on one side of the ring, just one. Now only the other half of the ring works. I tested this with my phone camera. I would like to know if anyone who comes by this post knows of any place that I could get a replacement infrared led set. Or replacement parts in general for the rift s controllers. I would buy a whole new controller but I don’t have very much trust for oem resellers. Unless anyone knows of a reputable reseller.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I did the same thing during disassembly while cleaning my Rift S controller joysticks. I ended up having to purchase a 10 pack of the correct IR SMD LEDs (part#:VSMB1940ITX01) and solder a new one in its place. Get in close with a camera and make sure there is still some solder pad remaining to stick it to before you take that project on. If you dare try this then get 10 of them. They are very small and pretty fragile so if your as unskilled as I am then your probably going to over heat the first 4 and crack them. I even cracked the 5th one a little on one corner but it still worked and has continued to for about a year now.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
water 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 46
总计 650
