跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
My left joystick button doesn't register
My left joystick button had drift and didn't register the stick button. I changed it for the right one on a different set of controllers that had no drift and did register the button. Drift is gone but the button still doesn't register. Is this a software issue or a motherboard/cord issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
have you tried calibrating it
完成的
Yes and updating it I assume updating is a software thing. I can do mine but not my son's aftermarket joycons. Updating and calibration didn't fix the lack of button register.
完成的
添加一条评论
1个答案
It could be a motherboard issue if it wont register a click even after switching them. Did the original joystick register click when you switched it to the right joy con? And if you have any working joy cons try switching them to further see if it could be the motherboard.
这个答案有帮助吗?
得分 0
1条评论:
No I didn't want to brave the interior again my son had a broken left I bought a new set of aftermarket joycons and when I read about drift being related to the stretching of the metal housing I decided to go ahead switch it out anyway, and try the other repair also. The drift fix was to place a piece of card stock the size of the joy stick housing under it to put pressure on the little square house of the joy stick. I used the right controller joystick because it worked fine minutes before the swap and my left wouldn't register the left joystick button. I figured it would be an easy fix. But the button still doesn't register I can dig the left joystick out of my junk drawer and try it I guess.
完成的
添加一条评论
添加你的答案
Patrick Lindsay II 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 617
