跳转到主内容
加入维修社区 - 创建账户
Repair information for the 4th Generation iPod shuffle. Released in September of 2010. Model number: A1373.
iPod won't turn on or won't charge
It was still in the package when I bought it. I can plug it into my computer, fine. The orange lighting blinks like it's charging, and itunes syncs with it fine, and itunes says theirs mp3s on it loaded fine. I have the latest version on it. I left it plugged in to charge overnight. I have tried restoring it.
But when I unplug it from my computer and flip the switch to shuffle or continuous, nothing happens. No audio and the battery indicator light doesn't even turn on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hi
Due to the iPods age it is most likely a bad battery
Battery’s degrade with age even if they are left sitting unused,heat can also affect a battery’s life span
Heres a guide showing you how to replace your battery
iPod Shuffle 4th Generation Battery Replacement
It is a soldering job just so you will need a soldering iron ,solder ,flux and a solder wick to do it
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
2条评论:
Thanks for this. I was afraid that may be the case. I don't have access or knowledge on soldering. I waisted $79 :(
完成的
@allura.morneau
I’m sorry to hear that
If you ordered it on eBay you could try and return it and get your money back
Or if you wanted I could show you step by step how to desolder the battery and put a new one in
It’s not too hard and soldering irons aren’t too expensive
Entirely up to you, no pressure just do what you feel is best:-)
完成的
添加一条评论
添加你的答案
allura.morneau 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 48
总计 2,045
