跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
Moisture in charging port, fast charging not working anymore
Ever since I got the moisture in the charging port notification, my fast charging doesn't work anymore. When I plug in the charger it shows fast charging and first then makes a second beeping sound and changes back to cable charge and also my phone doesn't charge when it's switched off anymore, only when it's on. Please what is the issue because I'm about to change the charging port board and I wanna be sure that's the issue so I don't waste money. So please help me out
What can be the issue here as I don't have any money for a new phone right now
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hi
Just adding to the amazing answer from @guardian10
Have you tried cleaning your charging port out with some fine tipped tweezers and some isopropyl alcohol
完成的
Yes I have tried cleaning with a tweezer but without alcohol though
Is the alcohol necessary?
完成的
添加一条评论
1个答案
最有帮助的答案
Changing the charging port is likely needed.
Samsung Galaxy S8 Plus Charging Port Replacement
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Emmanuel Ufot 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 21
总计 520
