跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
679 个问题 查看全部
Can’t add finger print to touch id.
Hello everyone,, I recently replaced a front camera/sensor flex on my iphone 8 plus. I know that true tone will disappear., but also can’t add any finger print to my touch id. Every time i try the screen just flicker/jumps up and down. Please any help appreciated. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I can think of a couple things. If it was just the front camera flex you replaced, my inkling is that the home button flex which goes from the display to the logic board may be pinched or was damaged during the repair.
Does Home button work? What was the reason for replacing the front facing flex?
这个答案有帮助吗?
得分 1
添加一条评论
You won't lose true tone as that's programmed to the screen itself. If you've just replaced the top ribbon then you won't of done anything with the home button apart from disconnected the ribbon from the motherboard. Open up the phone again and disconnect all three cables and reseat them making sure they are seated properly, especially the home button connection. Also check for dirt in the connectors whilst you're in there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manvir Garcha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 35
