How to use earphone type c on samsung galaxy a11?
Hi,
You may be able to plug the USB-C earphones into the USB-C port on the phone.
I'm not sure if your model allows audio through the USB-C port or not as the user manual doesn't show all the available settings.
Go to the Settings > Developer Options > Media > Disable USB audio routing and check that it is NOT enabled.
Here's a video that shows how to get enable Developer Options.
If the Disable USB audio routing setting is not there then I think that as you obviously cannot connect USB-C headphones to the headphone jack in the phone, you would need to use a 3.5mm male to USB-C female converter (you need to convert from an analogue signal to a digital signal) and they don't seem to be available. At least I couldn't find any.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 51
总计 2,688
3条评论
Why not just use the headphone port?
由 [deleted] 完成的
@strongbow
I took it to mean the the OP had headphones which had a USB-C connector and not a 3.5mm plug.
Cheers
由 jayeff 完成的
@jayeff I've no idea. I was confused because the phone already has a headphone port.
由 [deleted] 完成的
