跳转到主内容
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
286 个问题 查看全部
Panasonic SA-HE100 volume knob replacement
Hi,
I have a Panasonic SA-HE100 that is acting strange. The volume goes random up and down when I turn the knob.
My question is how do I find a replacement for this. The part # is RRV16B24304A but it is discontinued everywhere. I am pretty sure there must be an alternative part.
I mean how do you find out how many K's the encoder need to be?
Thanks!
Sch12 14
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @wadali_2000
Contact this supplier and ask if it is still available to order.
They're not showing "no longer available" as a lot of other suppliers are, so you may be in luck.
If they say no good then ask if they know of an equivalent replacement.
Worth a try anyway.
这个答案有帮助吗?
得分 1
3条评论:
Thanks but they said the item is unavailable and that they don't have any subs.
Is there any ways to find out the ohms on the original one?
完成的
@wadali_2000
Perhaps if the problem is intermittent you could remove the component from the board and then use an Ohmmeter to measure the resistance between the A & B terminals as shown in the schematics, first with it fully anti clockwise (min?) and then fully clockwise (max?) and note the resistances.
You could also measure between the Common terminal and the A and then the Com and the B and check.
To me it seems to be a potentiometer where the wiper (common terminal) is connected to earth and each of the volumes i.e. vol1 and vol 2is connected to A & B.
Just wondering if you centre the potentiometer to the mid point between min and max and then measure between common & A and then Common & B if you then add the two measurements together it may give the total for the pot.
Hopefully with all the measurements done above you might get some idea as to its value.
完成的
I was able to fix the noisy volume on a Panasonic SA HE100. I disassembled the unit so the front panel was removed. The took the circuit board off the panel to expose the control. The control doesn't have any openings to spray (deoxite in my case) inside, so I pushed two of the metal crimps on the control aside slightly and opened one side of it about 1/16 in and sprayed.
Put it back together and the volume control is perfect.
Mar 14 2024
完成的
添加一条评论
添加你的答案
Matthieu O 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 138
