iMac freezes at password entry
I have an older 27” imac running Majouve 10.14.6.
It has 32 MB of memory.
It has run flawlessly since new.
A few days ago, whenever I moved the pointer, I got the Beachball for a few minutes. This only got worse. Then when I restarted it, It gets to the password request – when I enter (and I know that I am entering the correct one) it freezes. But it doesn’t shake , like it does when a wrong password is entered.
Are there any suggestions as to the cause ?
What is your drive config? HDD, SSD or Fusion Drive. What is the size/s of the drive/s internally.
由 Dan 完成的
Some info about the specific model would be helpful as well as the type of storage drive in it (if you don't know the capacity and what model it is can help pin that down.
由 Alisha C 完成的
