跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
MacBook Pro won't turns on after a water damage to the trackpad
My macbook pro after I spilled a little water and honeslty didn't realize that it's toasted and so kept trying to turn it on. After like 48 Hours, It turned on then It kept working for few days after that trackpad stopped working. After some more days it stopped turing on. I did all that I was previously doing to turn it on like resetting PRAM, trying to boot in recovery but only SMC reset worked earlier which isn't working now. Now, When I try to reset the SMC by hitting the required keys, the charging led on the MagSafe just flicks for a bit but Macbook doesn't turn on. I opend the back panel and can confirm that the trackpad is toasted as there was little fuzziness on the track pad controller in the middle. I tried unplugging the trackpad but it didn't work either. Please let me what can I do. I am not in a position to afford major repair and I have a feeling that I can still get it working like I did last 2-3 times when it wasn't turning on and resetting SMC helped me turn it on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Just like a loaf of bread left on the counter which starts to go moldy, once it starts the mold won't stop! Even if you pull away the infected slices.
Liquid damage is not very different, once you have the spill letting it stew won't make it disappear!
Sadly, your system may have been left to long in this state. If you had addressed it sooner there was a chance to save it.
At this point you'll need to find a local independent Mac shop to have them check it out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adnan Nazir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 67
